發表於 31-10-2015 22:59
小弟剛入一架06 2.4Z Stepwgn 想換油。
1. 想問呢款車叫RG1或RG3?點去分辨?
2. 如果想換波箱油,應該用ATF-Z1或CVT?
3. 想換機油,Mobile 1 - 5w40 ok嗎?或有其他好介紹?
4. 師兄有乜好火咀同風格介紹?
uncola 發表於 30-10-2015 17:38 2. Honda CVTF or HMMF or compatible (I am using Jaytec HMMF as it is full synthetic)
3. Mobil 1 5w40 is the highest viscosity oil suitable for this engine. If you are a fans of Mobil1, you can stick with it, I think it is not bad, but you may consider 5w30 which give less loading on the oil pump to keep the fluent lubrication for the engine.
4. you better join the club, our committees have some group orders on the sparkplugs and performance filters.
5. if you have never drive a CVT before, then it may take you sometime to get used to the slow response on the kickdown action. |
