RK1保養問題 返大昌 定 自己車房搞
pls see 4#
各位好
剛買了一台二手RK1行車,7/2010 行左二萬幾km,保養期尚餘14個月。
買後發覺在停車場
kenlee880456 發表於 22-4-2012 17:48
What did u find out at the car park?
各位好
買後發覺在停車場
只係見到部RK1模型車?
買後發覺在停車場轉灣時車底發出有節奏的噠噠聲(開窗才聽到),之後比街外車房睇,車房回復懷疑橫濕頭、啤鈴蝕有虛位導致,俢理費約三四千。
本想交到大昌攪掂,但根據保養手冊記錄,上首車主一直未有返廠check車,問過行內人話到大昌首先要比五舊做保養轉名手續,再鑑粗要比三千幾換佢d平價油及check車,餘下保養期才生效。現有以下問題:
1)只行了二萬幾km,橫濕頭咁快打柴?問過一般車,要行了五六萬km以上先開始發作,有冇其它可能性(噠噠聲)?
2)返大昌是否一定要被屈三千幾換佢地D油才可延續餘下保養?
3)我打算更換呔鈴避震及包圍,會否影響保養?
4)如我在街外車房曾經維俢,還有保養嗎?
祝各師兄人車合一
謝謝
街外車整應該冇,我部06 RG1 都冇你所謂既噠噠聲
問多幾間格下價
問多幾間格下價
jackykiller 發表於 23-4-2012 00:20
間車房有幾熟先? 同埋平日行車有無聲?
FW. 大文
7# fw18
車房ok熟,行直路冇聲,轉灣先有
kenlee880456 發表於 22-4-2012 20:50
ball joint 塵冚入左沙, 上手楂得好粗下, 係工程車????
如果成日好快咁飛凹凸路面, 串魚蛋好快要換架la.....
1) 我估99%係ball joint 塵冚入左沙
2)  from what I know, you must need to have service with them regularly (so that they have your car's condition record) to keep you the warranty valid. 如果大搶係no charge fix the ball joint for you, then I think it is worth to spend money for 1 oil change with them.
3) what ever parts add-on option not via DCH, will not be covered in your warranty on those parts or related parts....e.g. if you replace the DVD, you can't expect DCH will give you warranty on that. But if you also have problem the OE speaker, they will ask you to put the OE DVD/CD system back, then they will check it for you.
4) you can fix your car outside, again depends on what those shop have done on your car......if you have rebuilt your engine, then you can't expect DCH will still keep the warranty on your engine la.....
2)  from what I know, you must need to have service with  ...
sammykwan 發表於 23-4-2012 14:21
好詳細,明白哂,many thx
不得不講句,sammy hing. 你好堅,好長,好盡
K'sworkshop 發表於 24-4-2012 10:04
大家鳩流下咁啫.....有錯勿插
