發表於 12-11-2013 11:14
本帖最後由 sammykwan 於 12-11-2013 11:17 編輯 二手買左架09年尾期RG1, 反吾反大昌做下service 同保養?佢地有個plan around 5K 有無師兄用過?因為買番黎個時左電門有2條约2cm花凹痕,影相睇吾到,問過打粗臘都吾得,所以順便睇下大昌焗番幾$度,吾想出面驚吾對 ...
aackm 發表於 12-11-2013 10:03  if you are a very picky person, then it would be a good idea to go back to DCH.
Coz DCH will provide you follow up service....(say the color is not match after paint, they may repaint it for you)
But personally, I will not invest so much on such old car. There are shops out there can also do a good job with lower price both on painting and maintenance service.
Most important is after you spend 5K on the service, they will have a full check on your car with changing all the fluid and consumable parts, but if they find there is problem with your car, say steering pump is leaking....will you let them to fix it? Which may cost you double to get it fix at DCH than from outside. |
