Stepwgn 2008 + iphone 叉電一問
各位C Hing,
我架車係日本水貨, 2008年尾..... 想幫部iphone係車到叉電 (我以前未試過用汽車叉電)
我搵到個"煙嘴"係中間控制波箱下面離地10寸的位置 (應該冇搵錯)
我將個叉電頭插入係"煙嘴", 但係唔知點解叉唔到電, 部電話一d 反應都冇.我試過將個叉電頭盡入但都係無反應.....
各C Hing, 有冇咪意見同辦法 ?
各位C Hing,
我將個叉電頭插入係"煙嘴", 但係唔知點解叉唔到電, ...
tonny_c 發表於 24-4-2010 23:09
Dear Brother, please share your experience on this topic, tell me the exact location of "煙嘴", I'm starting to confuse myself where is the "煙嘴". Attached picture from manual, is that the circled one calls "煙嘴", if not, where should it be ??? Many Thanks
Dear Brother, please share your experience on this topic, tell me the exact location of "煙嘴", I'm starting to confuse myself where is the "煙嘴". Attached picture from manual, is that the circled ...
tonny_c 發表於 27-4-2010 11:45
Yes, that's right.
I can charge up my Nokia cell phone, iPod, PDA and etc. by insert right adapter into the "煙嘴".
各位C Hing,
It only has power when the key is turned to ignition on.
本帖最後由 tonny_c 於 27-4-2010 12:50 編輯
sammykwan 發表於 27-4-2010 12:18
Sammy Hing,
How can I turn the ignition on ? do I need to press any button ? I only can see a hole when I opened the black cover and when I look inside, a white round plastic inside. I tried to press / twist / pull, no difference. my dear...........!
d 人話個個位可以用來點煙, 我覺得自己仲差好遠......
Sammy Hing,
How can I turn the ignition on ? do I need to press any button ? I only can see a hole when I opened the black cover and when I look inside, a white round plastic inside. I tried to pres ...
tonny_c 發表於 27-4-2010 12:42
擰條車匙一格="turn the ignition on" !!!
Perry2007 發表於 27-4-2010 12:16
Dear Perry Hing, is that the "right adapter" means normal adaptor for car use, no special type for STEPWGN "water Good" or "Hong Good" ???
tonny_c 發表於 27-4-2010 12:44
No special charger, they are all standard........but are you sure your charge is working?
And are you trying to charge the phone when the car is running?
12V點煙插,大多數是一樣的!
sammykwan 發表於 27-4-2010 12:46
Sammy Hing, I bought a new one in phone store, I tired to charge it when the car is running, but no feedback ???
alliven 發表於 27-4-2010 12:44
alliven hing,
個"long"入面有個白色的圈是否正常, 我覺得好似尼舊嘢預住左adapter入唔晒.....但又刮佢唔出....?
Please double check if your charger output is 1A or 0.5A .... if 0.5A .... throw it away ....
iPhone need 1A current to charge .....
joesik 發表於 27-4-2010 13:15
個adaptor本身如果有電到, 應該會着灯, 再插上專為iphone的線應該就可以叉電.
但依家連adaptor個灯都着唔到 ........?(架車行緊)
你住邊區?如香港區,出o黎大家研究吓,睇吓我o個cheap cheap adapter得唔得?
