發表於 18-9-2015 02:05
本帖最後由 sammykwan 於 18-9-2015 21:11 編輯 事原本人買車約1年多07年RG1,買車回來先換了波箱油,油格,偈油,火咀等等損耗品,半年換一次偈油及油格,兩次偈油都係換5w40,剛驗完車今次換油時,師父話副偈嘈,所以幫我用咗10w40,我再加咗半支ER,因第一次加所以 ...
jacko 發表於 17-9-2015 23:24  1st of all, since the RPM is down to normal range, you have reset the ECU correctly.
Now the problem is "you think" the RPM is dropped too low at some point (below 600rpm)
If I were you, I will not use 10w40, as it will take quite a while to warm up the engine oil to get into working temperature for this engine (it could cause low oil pressure when it first started). I would like to know if low RPM is only happened at cold engine or at anytime even the engine is warmed up.
One thing you may want to also check is open up the hood, and see if all the hose are fixed correctly, especially the air filter box is closed tightly (there are 2 clips to lock the lid)
Anyway, it may be just the idle air control valve takes abit more time to relearn from the new data after cleaning. Drive for a week more to see if everything gets back to normal. |
