發表於 12-1-2013 23:50
在什麼情況下需要換火咀?
我又唔知上手有冇換過,點樣可以撿查?
自己換難唔難?
各師兄有冇什麼牌子型號好介紹?
我車是08尾期RG1,煩請指教... ...
chillolau 發表於 12-1-2013 20:19  if you found the car the idle rpm is unstable, or if you realised the consumption is increased, then you should check the spark plug. Basically, spark plug is very long lasting, but just the matter of performance.
Some spark plug can last in good performance for only 10,000km, but some can last in good performance for 100,000km. Surely it is also depends on how you maintenance it....yes, you need to maintenance a spark plug. In order to clean a spark plug, the easy thing you can do is run on the hwy for a long distance to clear the carbon on the it. |
