6# gogo
大爪軨太空洞即係?
31# kane_l
Photo from 1 of the big black hole ching.
You can see , it need to add something inside.
原裝RK5後期 叫我GoGo 或者Terence
皮已收!!!咪諗住毒我. 無本錢吸毒.
19# DAN!EL
offset J數即係咩?
31# kane_l
gogo 發表於 19-3-2014 13:45
好空虛 好寂寞 好凍呀....
19# DAN!EL
offset J數即係咩?
kane_l 發表於 19-3-2014 13:46
copied from 細釘 earlier post:
比個網你睇吓,睇完好易明 http://peace543.pixnet.net/blog/post/30857716
王牛 Kingcow Eric
冷靜D
分清 想要 / 需要
本帖最後由 sammykwan 於 19-3-2014 13:56 編輯
19# DAN!EL
offset J數即係咩?
The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel. The offset can be one of three types (measured in millimeters). Backspacing, similar to offset, is the distance from the hub mounting surface to the inside lip of the wheel (measured in inches).
J is the width of the rim
You may also need to know the PCD, Stepwgn takes 114.3
number of holes, stepwgn takes 5 holes
sometimes, you will also need to know the thickness of the hub. As your screw may not be long enough.
唔該哂咁多位師兄,真係好多terms都唔係好明,要慢慢了解...
kane_l 發表於 19-3-2014 13:53
明咗,你就開始要搵解藥
王牛 Kingcow Eric
冷靜D
分清 想要 / 需要
明咗,你就開始要搵解藥
Kingcow 發表於 19-3-2014 13:59
唔明都可以搵「道」師 指導下
http://stepwgnhk.com/space.php?uid=5678
http://stepwgnhk.com/space.php?uid=15821
黎緊4月聚會。。 正正就會講呢樣嘢 offset , j 數
細佬-阿柱
39# sammykwan
睇黎係好德高望重既「道」師!
The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel. The offset can be one of three types (mea ...
sammykwan 發表於 19-3-2014 13:51
非常資訊性! 唔該哂,森美師兄,等我再研究下!
39# sammykwan
睇黎係好德高望重既「道」師!
kane_l 發表於 19-3-2014 14:10
小弟編號 5678
細佬-阿柱
細佬-阿柱
chclwong 發表於 19-3-2014 14:08
我要準備定教材先
