車呔壓力磅數...
各位大人:   我 2010 之 頭  尾  車呔壓力磅數是否 ... 頭33PSI      尾35 PSI  ...if refer to the lable sticked on the door's side wall ...              我打得 - 氣 - 正確嗎 ?      我唔 sure 喎 ?
2010 直板原裝車  ...       請賜教 ?!
Thx
如果原裝15"可以睇翻司機位門邊有寫廠recommendation.
... Thx .................  but some more straight answer ?
Learnt from the sales.  The front tyres should be 32psi, while the back should be the same for usual loading of 2~3 ppl.  If you have more ppl, your tyres should be up to 35psi.
Any c hing, pls share.
yes it is.33 and 35... but for me, I add 1-2 psi.. more.
I go for 35 front and back, 32 the tyre looks flat to me.
meowooi 發表於 8-12-2010 13:56
I put on 40psi some time.....wakakakakakakaka.....as long as not over 50psi, it won't blow up.
Mine, 32 is enough..
The front tyres should be 32psi, while the back - your tyres should be up to 35psi.
... so the answer should be :   32 psi for front  and then  35 for the back,  right ?
(這跟 driver seat 門邊之 "貼紙" 寫法吻合 !! )            Thx
我會入36 psi....正確嗎?
我會入36 psi....正確嗎?
jay 發表於 10-3-2011 23:37
32 ~ 34 psi enough lar
咁我下次入35 psi....我鍾意硬身點,好行d
我換左18吋,剛回大昌第一次check車,佢幫我打 前38 後40 .
38-40psi, 太高了吧....
本帖最後由 fw18 於 11-3-2011 12:25 編輯
38-40psi, 太高了吧....
mnywong 發表於 11-3-2011 11:53
是啊! 呔薄又唔需要打噤高.....
睇過外國網頁有話 +1",+1psi,唔知啱唔啱....
